‎29-05-2024 04:59 PM
My phone works fine but my wife's phone doesn't appear to be working as EE hasn't allowed roaming request which we sent before leaving UK. Any suggestions?
‎29-05-2024 05:14 PM
@Tolley1947 : What roaming request exactly & how did EE refuse it?
Where are you?
‎29-05-2024 06:12 PM
@Tolley1947 Do you have a spend cap of £0 on that account for this sim? If so and you are within the EU you’ll not be able to pay the daily roaming charge £2.47 unless you purchase the roam abroad pass or change that spend cap. But where are you ?
‎29-05-2024 06:30 PM
‎29-05-2024 07:13 PM
As you never answered I'll just have to guess.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
