on 14-06-2024 04:17 PM
Hello,
I was told prior to going to Germany that my roaming would work, I setup roaming before I left, did all the steps and it didn't work once in Germany. I folllowed avdvice online and nothing worked. I get the feeling that the network just doesn't work in Europe . I'm travelling to Europe again and I want to make sure I can acess the Internet and make calls while I'm away can I buy an add on that's guaranteed to work?
on 14-06-2024 04:34 PM
The network-level permission for your SIM to connect to foreign networks is not obtained by having add-ons, these merely reduce the cost of roaming abroad.
on 14-06-2024 04:59 PM
Yeah I did and it still didn't work - I'm guessing there's no way to use it in Europe then. That's pretty dissapointing
on 14-06-2024 05:08 PM
There's a diff between texting ROAMING alone & texting ROAMING PASS. Which did you do in the UK?
14-06-2024 05:09 PM - edited 14-06-2024 05:10 PM
I'm assuming you're on pay-monthly, did you receive text confirmation of roaming being enabled - can you post a screenshot? What happened when you tried manually connecting to each local network? Have you been able to connect to networks in other countries?
If all EE users were genuinely unable to use their phones in Europe, this forum would be absolutely chock-full of complaints - that's not the case.
on 14-06-2024 05:16 PM
Yeah and yeag I did.
I tried a few different networks manually when I was there and none of them worked - I couldn't phone 150 to fix it becuase it wasn't working.
When I used my phone in Europe and the US I had no issues previoulsy but the last time I'd used it in Europe would have been 2023, maybe earlier.
There's quite a lot of posts about it not working in Europe on here and on reddit - particularily in Germany so maybe it's a localised thing
on 14-06-2024 05:17 PM
I texted roaming and got a message saying my phone was set to roam in any country
on 14-06-2024 06:09 PM
Did you receive a welcome text from EE when you arrived in Germany, @Maytoot?
Had you purchased a roaming pass?
Do you have a spend cap on your account?
on 20-06-2024 12:00 PM
Yeah I did recieve a text
No I didn't purchase a pass, is there a pass for Europe?
No I don't
on 20-06-2024 12:46 PM
Hi @Maytoot,
Yes, please see How Do I Get the Roam Abroad Pass? | Roaming Help | EE for more details.
