Roaming
MariaR
I am abroad and Roaming is not working. Even though i have it on my plan. How do i get in touch with EE? They don't have any options to chat with them unless i go in store. What is this nonsense?
Schockwave
@MariaR , are you on pay as you go or contract? If on contract did you activate roaming on your account? No need if on pay as you go, as it is automatically enabled.
Did you receive the welcome message when landing ?
Often just rebooting the phone, you should see network enabled. You can also try a manual search for a network.
If you need to contact  customer service, you can use Skype to contact them for free, see my signature.
