Roaming canada
Jlow3
I turned on roaming before leaving the UK , and had text messages sAYing its on, but nothing works - HELP i cant look up tours, places to go etc,
Northerner
Hi @Jlow3
Have you checked roaming is activated on your phone under settings?
Have you checked roaming is activated on your EE app/online account?
Ha e you tried to connect to a network manually?
@Jlow3 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
Thanks, done all that as seen a previous answer, unfortunately cs are too busy to answer, still stuck with no data
