Roaming bolt on not working
Wardm1102
Currently cannot connect to foreign networks in Canada despite there being signal on partners EE bolt on sim, we both have the add on but don’t know how to fix the issue, unable to reach a human and the ROAM text to 150 won’t go through
Christopher_G
Hi @Wardm1102
Welcome to the community.
Are you having problems with calls, texts or data? Have you tried restarting your phone and manually selecting a different available network?
Are you on contract or pay as you go?
@Wardm1102 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
