15-04-2022 11:38 PM
Currently in the US and can’t get mobile roaming to work. The text from 150 says it’s enabled but when I check my settings it says it’s blocked.
15-04-2022 11:45 PM
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. over Skype. It should be free.
15-04-2022 11:45 PM
16-04-2022 09:21 PM
Can I ask did you get roaming to work? Going to USA on Tuesday and have activated roaming and paid for the Roam Abroad Pass but in settings still says Roaming Blocked.
16-04-2022 10:12 PM
Spoke to CS, via SKYPE, and he added a pack to make it work. Apparently I had an old add on. All sorted now
16-04-2022 10:15 PM
Eh? Packs are for PAYG. You don't have PAYG.
17-04-2022 08:16 AM
Morning @Ssncraw
Thanks for coming here.
If you give us a call on 150, the team will check your roaming settings and make sure you're all set up to use your phone abroad.
Hope you have a lovely time.
Leanne 🙂
