Roaming and data not working
Njj1985
I've just arrived in the US and usually I would get a text message from EE to see if I want to use my data. I didn't receive anything, I tried to text 150 using WiFi but it isn't sending. I've just added the roam further pass but it's made no difference. I can't phone any helplines as my phone won't allow it nor can I send texts
@Njj1985   Wi-Fi calling doesn’t work when roaming so text via Wi-Fi will not work also.
 Have you restarted the device?
@Njj1985 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
