Roaming abroad
Markleeee
How do I set up roaming on my phone when I'm already in france
@Markleeee : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
