Roaming Abroad
Groundrush
I have 3 simms on an account with EE. Have paid for monthly data roaming abroad on all 3 but for some reason it doesn’t work. Have tried purchasing again and can’t. App says it’s current. Can’t get in touch with EE! Currently in Mexico City and lack of data causing problems!
@Groundrush : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
Thanks for your reply! The roaming abroad option was not ticked but the i can not tick it. Says there is a problem. Been in the EE holding queue for 20 mins now!
Leanne_T
Hi @Groundrush
Thanks for calling, the team will get this looked into when they are available.
