Roamin Pay mthly SIM (orig PAYG) not recognised by EE network for incoming call
JackBhar
Hi
I have a Pay monthly sim - shifted from PAYG about 2 years back.
I am now in India for a month. Before leaving the UK I chose "Always call forward" from my Samsung S10e.
Now in India, my SIM does not register on the network and I do not receive SMS - a major problem if I want to make any bank transactions.
I cannot make / attempt outgoing calls, and when I call the number, the UK EE network says that "You have dialled an incorrect number"!
I used the number continuously in the UK so it ain't!
I have tried switching the SIM to other phones but to no avail!
What could the issue be?
Please let me know!
Also to turn off / on call forwarding, do I have to activate data roaming for a day least?
Regards
Jack Bhar
@JackBhar : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
Trying to set it through the account manager did not work. It just went back to not allowing roaming. The account is a family account managed by my wife.
The number you gave does work through Skype - waheyy!
The automated messages suggest that EE will send SMS's about roaming, and asks me to send SMS to 150, which clearly I cannot receive or send as roaming is not enabled!
Anyway will discuss with CS once during opening hours.
Thanks for your help.
JackBhar
