Re my phone
webby07974
I want to put a 24 hour block on my daughters phone as a punishment how do I do this?
Alex_M
Star Contributor
Star Contributor
Hi @webby07974,
There is no way to block the sim yourself, you would need to contact EE directly and have them block it - but usually this is only done is a device is lost or stolen, and it would require you getting a new sim card.
Personally I would just take the phone all together as even if you blocked the sim, wifi, games etc would work just fine still.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
