05-07-2022 05:53 PM
So two weeks since Calls Over Wifi failed and it seems to have happened again.
Is it just me? - its been fine for two weeks - but just come home, tried all the usual resets / flight mode etc.. still won't reactive
30 minutes on hold to ee "we are experiencing very high numbers of calls"
05-07-2022 05:59 PM
Hi Brian - my wificalling is ok at the moment…fingers crossed!
05-07-2022 06:01 PM
Hi @brianotoole
Thanks for coming back here.
Can you try restarting your phone, does this work for you?
Leanne 🙂
05-07-2022 06:06 PM
yes tried that a few times - still no joy
05-07-2022 06:11 PM
Thanks @brianotoole
Are other devices connected to the WiFi and able to use WiFi Calling?
Thanks.
05-07-2022 06:17 PM
Hiya, who is your broadband with? Ours is with EE and when I phoned them they said it was an issue with which connects I connected to, either 5 or 2.4, mine only works on 2.4. They renabled the 2.4 and it worked straight away. It's a bit patchy but at least I can get calls though. Might be worth checking?
I found this after I did a complete factory reset, which is absolute pain resetting all authenticators and completely didn't help!
05-07-2022 06:20 PM
Ours isn’t working either
05-07-2022 06:21 PM
I only have this phone - just getting very weak signal or 'emergency calls only' - has been fine here for years.. untill two weeks ago - then it came back the following morning..
... now gone again
05-07-2022 06:24 PM
@Leanne_T No one in our house can access WiFi calling either - 4 of us are with ee … have restarted router and phones … nothing !
05-07-2022 06:26 PM - edited 05-07-2022 06:27 PM
Thanks @brianotoole @alisonsweeney
Which model phones are you using?
Do you have EE Broadband?
