Roaming Pass
HaastrupD1
  • I am in the USA and want to use my data, texting and make calls while I’m here. I have paid for Roaming Pass £10 add on but seems not working. How long will this be activated?
    If it’s not going to work, I hope I can have my money back?
  • Any advice will be appreciated
@HaastrupD1 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
Many thanks for the detailed update astonishing the prerequisites of roaming.
The only box I did not tick was sending “roaming pass to 150” prior departure UK. While every other boxes were ticked.
It showed on my EE as activated, unfortunately I still can make call neither being able to receive call.
Maybe, I will need to end up using Skype free phone to call customer services for further help.
Many thanks again.Haastrup
