Re: Unlock voicemail
dave_101
@Leanne_T
Have you actually tried this?
When you call 150 and try to get through the IVR to get to speak to someone about unlocking voicemail, you will find it impossible. The system has NO OPTION for being put through to a human to do this.
Perhaps you could arrange for someone at EE to make that a new option on the IVR.
Cheers
Dave
6 REPLIES 6
 You should be able to choose the technical support option to speak to a CS agent who can resolve a voicemail issue.
davidgc
I have been trying to do this this afternoon and finding it impossible to speak to someone. Really dissapointing as EE have normally been fairly good when you have an issue but not this time
Katie_J
Hi @davidgc.
Since your post have you been able to speak with a member of the team?
Katie
Same problem experienced today
DerkT
When you select option 2 it then gives you two options 1 or 2.  You then press 1 and it gives you two options 1 or 2.  You then press 2 and it tells you that it is texting you the information and hangs up. So I can not actually do what I rang in to do which is get my Voicemail unlocked.  Bring back human beings..... Frustrated of East Yorkshire
James_B
EE Community Manager
Hi @DerkT,
Have you tried starting a live chat from the help tab in the EE app?
