on 10-10-2023 12:20 PM
My partner and I are having the exact same issue we aren’t able to use our phones without being connected to wifi and we have the roam abroad pass / roaming switched on in our phone settings.
on 10-10-2023 12:25 PM
Your post has been moved to a new thread, although the advice will be exactly the same as to anyone else with the same problem.
You have purchased a billing add-on, this reduces the cost of roaming but doesn't enable the roaming facility itself - which is what allows your phone to connect to foreign networks. This free of charge facility is not something you can enable in your phone, it's a network-level permission that is normally done by texting ROAMING to 150 before leaving the UK. Did you do this?
The phone setting you're referring to, is very likely "data roaming" - this simply enables mobile data whilst roaming. There isn't a phone setting for "voice call roaming" or "text message roaming", but that would be the equivalent.
