Re: Roming from abrod
Mohammedamini
Hello mate also i have same problem I’m in iraq right now but my sim card doesn’t work it says no service  before I left UK i did activate my roaming data
Leanne_T
Hi @Mohammedamini
Thanks for coming here.
Do you have a pay as you go or pay monthly account?
Have you tried manually selecting another network?
I have pay as you go account, because I don’t have service I can’t do nothing, I don’t know what i need to do now
@Mohammedamini   You don’t activate anything for PAYG as it’s pre pay.  There is no option to enable roaming for PAYG.   Try restarting your device and try a manual network search
@Mohammedamini : Did you use that PAYG SIM for making calls or texts in UK before you left to go abroad? EE PAYG SIMs need 1st activating on EE's home UK network before they can be used abroad. If it wasn't you can't now use it until you return to UK.
