Re: Roaming in Europe
Mamad1946
I need roaming.
1 ACCEPTED SOLUTION
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
Mamad1946
I am in Spain and I need roaming.
