13-03-2024 01:44 PM
I am abroad in Trinidad and Tobago and can send and receive texts to the UK but cannot make calls. Yes I did call before I left the UK, yes my roaming is also on.
13-03-2024 01:54 PM
Did you receive a welcome text when you first arrived abroad? What happens when you try making calls?
Are the symptoms identical on each local network?
13-03-2024 03:27 PM
Yes I received a welcome text.
When I try making calls it says - the owner of this account has restricted outgoing calls ID 15
13-03-2024 06:53 PM
13-03-2024 09:56 PM
I have no idea...how do you check?
13-03-2024 10:41 PM
The text "spend cap" in the previous post was a weblink. Click it and Spend Cap will be explained, together with advice on how to check.
The symptoms of spend cap would be an ability to connect to local networks abroad but not incur additional charges, which calls & texts would be. If you're close to a cap, then smaller charges (such as texts) may be OK but larger charges for calls could be affected.
14-03-2024 03:20 PM
Thanks so much for all your assistance. I finally got to my link my SIM to my account and saw that my cap is zero.
I'm hoping this means I don't have a spend cap and all should be good with at least that part, no?
14-03-2024 03:24 PM
If you have a spend cap of zero, this should be preventing charges applying - and will at least be part of the cause of your symptoms, if not the sole cause.
You will need to increase your spend cap to allow roaming charges to be incurred.
