18-08-2025 08:50 AM
So, how much data do I get while roaming? Because EE has not sent me a 80% of your limit text. According to my iPhone, while roaming, I have used 42.7GB. How much data do I actually get? I’m using a ROW pass.
18-08-2025 08:56 AM
Up to 50GB per billing month is the Fair Usage Policy while roaming.
So if you have 125GB or Unlimited you can use up to 50GB, or if you have 25GB you can use your entire allowance essentially.
18-08-2025 08:57 AM
Yea but does re text you when you have done 80%
18-08-2025 09:02 AM
Is that over just this roaming period or a combination of previous periods of Roaming?
There should be a date of last reset at the bottom of your iPhone data usage page, this will show when this total started being counted.
Unsure if a text is sent as I have never managed to use anywhere near the 50GB personally.
18-08-2025 09:17 AM
My last reset was 11May. The last time before now was on April. No roaming have been used before.
18-08-2025 12:16 PM
@Arnedin-Armin
If your monthly allowances refresh on the 11th each month, your roaming allowance would also refresh on the same date. Your new allowance to use while roaming would have began on the 11th August .
Don't worry, it's not possible to accidentally exceed your data allowance while roaming, so you wont incur any unexpected charges.
Which date did you go abroad?
Ali
