Re: Roaming Fair Usage
Co9997
Hello, I am currently abroad in the U.S. and my roaming is not working. When I check in the app the roaming worldwide toggle is off and when I try to turn it on it has an error message / is blocked. Can you please help? I am paying for roam abroad
Leanne_T
Hi @Co9997
Thanks for coming here.
If Roaming is showing as blocked and you are unable to activate this, you would need to give us a call from another phone on +44 7953966250 and the team will help you get this sorted.
