Re: Phone going straight to voicemail
themanc
Did you ever find the issue? Seems mine is doing it too for some people. Sometimes it works, sometimes it goes straight to voicemail.
Mine is Pixel 8 pro and no idea what setting is amiss. If I go into settings and look at 'Calls and Sims' they both show as defaulting to EE but greyed out, so I can't go in to check or change any settings
Very frustrating
Can you use mobile data whilst on a call? This is a good indication of VoLTE being active.
Are these missed calls happening in a specific location, or more generalised?
Yes I can use mobile data
The recent times I have been made aware were when I am at home, but I can't 100% guarantee it only happens when I am at home of course
James_B
EE Community Manager
Do you have WiFi Calling turned on to improve your indoor coverage, @themanc?
didnt have it switched on so will give it a try - thank you
Leanne_T
Let us know how you get on @themanc
