on 11-11-2023 01:55 PM
I am receiving texts but all incoming calls all go straight to EE voicemail, have tried phoning techies but they have no answer at all, it's dire. A complete disaster.
Solved! Go to Solution.
13-11-2023 03:26 PM - edited 13-11-2023 03:26 PM
Apologies for the mistake @LesleyChiles, I am very sorry this has not been done for you. Did they advise you to try any troubleshooting when you last called?
Have you called the team again today?
on 11-11-2023 02:35 PM
I am receiving texts but all incoming calls go straight to EE voicemail, have tried phoning techies but they have no answer at all, it's dire. A complete disaster.
First initiated transfer on Friday 3rd November, sim arrived Tuesday 7th November. I did not immediately change the sim as was making journey to St Austell and needed phone for journey but ironically halfway home at about twenty to 13:00 or so I lost my plusnet signal. Arrived home and put temp sim in phone and made call as had been requested. Then put my sim back.
I appeared to be on EE but no-one can phone me without it going to voicemail. Today is Saturday 11th November, I can only receive voicemails, the only live call I can receive is from a BT landline (i.e. EE).
I can receive text however.
As i have said technical support have no answer when I call them.
on 11-11-2023 06:22 PM
Is this a recent problem?
Have you made any changes to your account, or recently ported a number in?
If incoming texts are working but calls are failing, the initial check should be for call diverts - check your phone's settings for any "divert all calls" option that you may have inadvertently set, and cancel them if so.
When you reported this issue to EE-CS, and they (from the sounds of your post) said "sorry, don't know" - was that how the call was left? Did you not query what the next step was?
on 11-11-2023 07:10 PM
on 11-11-2023 07:11 PM
on 11-11-2023 07:56 PM
@LesleyChiles , have you rebooted your phone? Have you also checked in settings that it shows your number and not the one that came with the EE SIM card?
on 11-11-2023 08:04 PM
Best to only post once in one thread to avoid confusing with multiple posts.
Your symptoms are consistent with incomplete porting data, which CS have processes to resolve - if restarting your phone hasn't resolved.
If one agent you spoke to was unwilling to assist, I would suggest insisting that they find another agent who is willing. If they still refuse to assist, callback and speak to someone else.
on 11-11-2023 09:36 PM
on 13-11-2023 10:31 AM
Thank you but CS are unable to help.
They have no idea
on 13-11-2023 11:14 AM
Which device are you using?
Are you able to try the SIM in another phone to see if you can receive calls?
Leanne 🙂
