Re: EE Roaming - Help when abroad with your EE phone or device
Irate1
I am totally stranded without a phone in USA. No calls, no texts, no data. No help from support. I have tried everything above. I cant find my post but I got an email saying click solution so I guessed they archived it but I have no solution. I can't call customer services because I cant call, chat isn't working, I cant login to my ee account it says sorry there is a problem at the moment. It worked for approx 3 hours in detritus and 2 lots of 5 seconds when I was chatting to support enough to receive a few texts. In my situation you and formal complaint are my last options
Irate1
Detritus = detroit
The 2 lots of 5 seconds are in indianapolis
Jon_K
Former EE Employee
Hi @Irate1.
Are you able to log into your My EE Account now?
What phone are you using?
Can you try manually connecting to another network?
Jon
@Irate1 : Look in your Profile from your avatar at top R of any Community page or at the top of any of your posts to see all your posts.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
Sorry this didn't help.
The problem is EE relationship with US networks but for completeness
I couldn't call customer services because the phone wasn't on a network.
I have roaming and sufficient data
The contract is part of ~20 mobiles my company currently gets from EE
I posted the solution i found
Not only don't use 4G
Dont use 2G/3G automatic
Use 3G only and manually connect to T-Mobile not AT&T
This is a failure of EE relationship with US providers and a shocking lack of consideration for customers who find themselves in my position
So call CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
