Re: Does Wifi Calling work with Gigaclear installed instead of eg Plusnet?
LenFo
Hi
l can’t get wifi calling to work with Gigaclear.
are there perhaps SIM card compatibility issues?
cheers
LenFo
Forgot to mention, mobiles are EE !
Katie_J
Hi @LenFo
As another user has confirmed they are on EE and can use Gigaclear WiFi Calling there would not be a compatibility issues.
What phone are you using? Has WiFi Calling worked on other networks OK?
Katie
Hi Katie
On a good day we have one bar 3G signal strength but a good quality broadband of 100Meg +.
Our phones are not the latest 😒
Samsung A22
Samsung A40
could that be the problem?
we haven’t knowingly used wifi calling elsewhere.
At home for friends and family we revert to WhatsApp or FaceTime for calls but often need to use mobiles .
thanks
@LenFo  It doesn’t matter how old the device are if they support Wi-Fi calling as they just use a Wi-Fi connection to connect to the network.    Your issue could be with the firewall of your router blocking this from working.   This was the issue when Wi-Fi calling started to roll out.
Some Android phones have an option to set "WiFi preferred" or "mobile preferred", that's an option worth checking and potentially experimenting with.
Historically, a 2G or 3G coverage layer would be a lower priority than WiFi-calling, but I'm not convinced that's currently the case.
Has anyone else been able to use WiFi-calling when connected to your broadband router? The ports used are universal.
