Re: Changes for EE customers roaming in the EU
Evalin
Yea, I have all that, but my phone still doesn't work in Hungary. 150 doesn't work either, and no other helpline number to call - well, I can't call ANYONE! I need to make calls urgently, that's the whole point of this trip, sorting out care for my mum.  HELP!!!! Eva
xxxxxxxxxxxx
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
@Evalin  Is roaming enabled on your account?
@Evalin : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
