Raining in US
Georgeeaton95
Hi guys - my 4G isn’t really working when out in New York - any suggestions? In NY
Do you have coverage from 2G/3G instead? Or are you reporting a complete no-service scenario?
If the latter, are you on PAYG or pay-monthly? PAYG is auto-enabled for roaming once used in the UK first, while pay-monthly needs to be enabled via your myEE online account or app.
I only have 5g or 4g options in my phone. Just getting the E signal with 4 bars but nothing else
Are you on PAYG or pay-monthly? PAYG is auto-enabled for roaming once used in the UK first, while pay-monthly needs to be enabled via your myEE online account or app.
If you have signal bars, this would tend to suggest you are already connected to a local network in the US. Are you able to make calls?
@Georgeeaton95 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
_MrR_
Scholarly Contributor
Are you roaming on AT&T?
If not, might be worth doing a manual network search and selecting them. Had really good 4G and 5G coverage when I was there a few weeks ago
