on 28-05-2022 07:31 PM
I’m currently in the US and am using the Roam Further Add on.
If I allow automatic network selection I always get T-mobile which rarely works successfully to allows me to use mobile data.
If I turn off automatic network selection and manually choose AT&T the connection is much better.
Am I allowed to do this under my add on or do I have to use the network automatically selected?
on 28-05-2022 07:35 PM
You may select any local network that'll take you. Manually selecting the network is often the way out of many roaming issues.
