15-09-2023 08:42 AM
Hello, im connected to wifi in my hotel but i cant get a signal on any network, my phone normaly works fine when abroad, my wifes phone which is working is also on my ee account but will not ring ee. I need to check the charges and spend caps etc, i checked before i left but it said normal uk charges apply, but now i feel the need to worry, thanks
15-09-2023 10:54 AM
Hi @Clarky456
Thanks for coming here.
Have you tried manually searching for a network in your phone settings?
You can check the Spend Cap in your My EE app then Settings, Spend Cap and you can change this if needed.
Leanne 🙂
