on 21-04-2023 11:49 PM
Phone doesn’t work abroad
on 22-04-2023 01:11 AM
In what way does your phone not work abroad - does it have a connection to a local network?
Is the phone on PAYG or pay-monthly?
on 22-04-2023 01:41 AM
It has no connection/service or 4G
Roaming is switched on. I did text 150 before I left the uk but not had a reply and I can’t get a reply now as no service.
I am on pay monthly
on 22-04-2023 07:22 AM
Hi @Saturnbb64
Thanks for coming here.
Did you text ROAMING to 150 before traveling?
Can you manually try and connect to a network in your phone settings, do you get signal after doing this?
