Phone won’t work in Spain
Tiernan01
I have the relevant contract for data roaming but phone won’t work . Only just arrived . Cannot get through to customer services of my friends phone
The relevant check to use any pay-monthly phone abroad, is that roaming is enabled on your account. Data roaming is just a facility on your phone that, if it's connected to a foreign network, data use is allowed.
To check whether the ability to connect to foreign networks is enabled on your account, login to your myEE online account or app, and navigate to "parental & data controls". Check the following 2 options are enabled
1: "International roaming"
2: "Call abroad & Premium rate"
Thank you
Have done that. Still not working . Won’t let me text Roaming to 150 neither
Sent from my iPad
Are the two options showing enabled?
If yes: Then roaming is enabled on your EE account and I would recommend restarting your phone and/or selecting a local network manually
If no: You will need to contact EE CS to enable the roaming facility. You can do this either from another working phone, via a webchat session or a web-calling app.
@Tiernan01  Have you restarted the device since you got there ?
