08-08-2023 04:14 PM
08-08-2023 05:28 PM
Are you on PAYG or pay-monthly? The process to activate roaming - which is what allows your phone to work abroad - differs between them.
If you're PAYG, roaming is auto-enabled providing your phone is used in the UK first.
If you're pay-monthly, you need to enable it before leavigng the UK, which is normally done by texting ROAMING to 150
