Phone not working abroad
BenHindley
I’ve bought my data pass and I can’t get sang sort of signal on my phone
Leanne_T
Hi @BenHindley
Thanks for coming here.
Have you activated Roaming and Call abroad in your My EE account?
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
