on 23-09-2022 07:58 PM
I am in USA Nashville and I have no roaming while I have been here
Solved! Go to Solution.
23-09-2022 08:04 PM - edited 23-09-2022 08:05 PM
@Jakegosling8 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
