Phone can’t make or receive calls in Portugal
CamHughes
Hi there
I have set up roaming, I’ve checked the network settings, I’ve checked my spend cap, and I still can’t receive or make calls. I can’t contact EE because there’s no text or email option. I know I have voicemail messages but I cant listen to them. Can anyone help?
Northerner
Hi @CamHughes
You cannot have roaming set up. You'll need to use Skype over wifi and use the number in my signature to contact EE CS.
@CamHughes : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
@CamHughes wrote:
Hi there
How exactly did you setup roaming? And how did you get confirmation? The only network setting to enable roaming is on your account, although many people confuse their phone's "data roaming" menu option - all this does is allow the use of mobile data whilst already roaming.
