on 15-07-2025 02:24 PM
West midlands - 100% reliant on calls over wifi
Can make calls fine - but nobody can get through to my phone
Seems better when it drops back onto 4g out in the garden
Have restarted phone / activated Plane mode / Wifi Call then comes back.. but nobody can get through
Is it just me?
Solved! Go to Solution.
on 15-07-2025 04:49 PM
Hi
Thanks for the mesages
4 hours later - seems fine again now - receiving calls over wifi all okay
15-07-2025 02:47 PM - edited 15-07-2025 02:48 PM
What happens with incoming calls when your phone is using WiFi-calling?
Is there any difference when you're on an active call?
How long has this been a problem?
Can you send & receive texts while on VoWiFi?
on 15-07-2025 03:02 PM
Hi
Thanks for the reply
It just seems to be a problem with calls over wifi - but I can still make calls fine - just cant recieve them and there is no answer phone option... its just dead when people call my number.
Yet its fine when I'm away from the house and not on wifi (unfortunatley no signal whatso ever inside - so I'm totally reliant on calls over wifi)
on 15-07-2025 03:38 PM
You've not answered whether incoming calls function (as call waiting) when you're already on a call. Nor whether you can receive text messages.
How long have you had this problem?
on 15-07-2025 03:42 PM
Text messages - yes fine
Call waiting / incoming at the same time tricky to test
But calls - outdoors within same postcode (ie: not over wifi) - also fine
on 15-07-2025 04:11 PM
Hey there @brianotoole.
Thanks for taking the time to reach out to us about this!
Whilst simple, as a first port of call can you please make sure that your handset is fully up to date at the moment?
Also don't worry if you're not sure, but are you aware of whether other WiFi networks exhibit the same issue, or is it just via your home network you've tried this?
Peter
Hi
on 15-07-2025 05:17 PM
Hi @brianotoole
Thanks for coming back and letting us know this is now working again for you.
Leanne 🙂
on 18-07-2025 03:32 PM
Sorry to drag this back up again - was fine again - until now, just noticed the same happening:
Calls Over Wifi (essential)
I Can call people - no problem
Peole try an call me - but doesn't even ring out. All I get is missed call message.
If I turn 'wifi calling off' and leave the phone by a windo so it occasionally picks up the weak signal - people can call me again.
Not ideal.
on 18-07-2025 03:46 PM
I notice you've had this problem previously (here )
I'd be interested to test whether an incoming call works when you're already on a call. The setup process is subtly different here, and that would be something to eliminate.
The next step could well be to provide dated & timed examples of missed calls, to EE-CS for further investigation.
