Overseas
Jackyge
I have just arrived in Australia and I can’t use the mobile carrier- I just get SOS . I purchased a package for using my data here whilst on holiday.
what should I do ?
Katie_J
Hello @Jackyge
Are you a pay monthly customer?
If yes, did you activate roaming by texting ROAMING to 150 before leaving the UK?
Katie
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
