18-10-2021 06:31 PM
Hi, I have not been able to receive texts for the last couple of days. I can send texts, make calls and receive calls. I have cleared cache data for messages and removed sim & restarted, but doesnt work. Any ideas please?
18-10-2021 08:14 PM
Hi @Lou1505
Is this affecting all texts from all senders?
What happens if you send yourself a text message?
18-10-2021 08:27 PM
Hi, yes its texts from all senders, sending myself a text msg doesnt work either...
19-10-2021 08:10 AM
Are you currently in the UK or roaming abroad, @Lou1505?
Are there any maintenance works listed in your area. You can find this out by checking the 'status' of your postcode on our coverage checker.
19-10-2021 02:53 PM
Hi, I'm in the UK and have checked the coverage which is fine...
19-10-2021 02:55 PM
Did you check the status of the network, @Lou1505.
That tells you if there are any faults in your area.
19-10-2021 03:06 PM
Yes, the status said 'no known problems'. I have removed the SIM card again and restarted but still nothing, the SIM card looks quite worn out though, could this be the issue?
19-10-2021 03:40 PM
OK, thank you, @Lou1505
I would recommend either reporting a problem on that status checker or getting in contact with our technical support team so this can be investigated further.
