14-11-2025 01:58 PM
Hi
For the last two years, my husband and I are not receiving text messages regularly in our area/home. It's frustrating as we need this when making purchases or logging onto accounts.
Is this an issue for others?
03-02-2026 06:08 PM
Not so much a setting needing tweaking, but an investigation as to why subsequent texts are being delayed.
Timed & dated examples, quoted to CS, would be the way to go here.
14-11-2025 03:26 PM
Can you reliably receive calls in your home/area?
Are these text messages never received? Or just delayed? Is there any pattern to the messages that are delayed?
Do you have any issue sending text messages in your area/home?
14-11-2025 07:02 PM
Hi @Joolsmc
As you're both facing an issue, you can check coverage and network status at Check mobile coverage where you can report any issues you are facing, as well as sign up for updates on any known issues that may be going on.
If there are no issues in the area, I'd recommend calling Customer Service where a guide can check your mobile connection and message deliveries, and refresh your SIM connection if needed.
In the mean time, it may be worth setting up WIFI calling if you have a fixed line Broadband service at home.
Ali
15-11-2025 12:56 PM
15-11-2025 03:01 PM
SMS should be more resilient to poor coverage than calls, but ultimately if you're experiencing call drops & SMS delays, this may just indicate a coverage issue. I don't see the merit in disabling WiFi-calling for anything other than testing purposes - the service is designed to only kick-in when necessary, and if it improves service & reliability, then the case is made.
If there were more to this than poor coverage, then the questions posed previously apply..
15-11-2025 07:21 PM
15-11-2025 07:36 PM - edited 15-11-2025 07:37 PM
@Joolsmc wrote:
I suppose I want to test the system...
Very few text messages are received, never delayed.
Try sending text messages to your own number. Are they received?
By the same argument, try using the 150 text message service. Send a command such as HELP or BALANCE to 150, you should receive a response by text message.
A quick & easy way to prove receipt of text messages. Try doing this from any phone that you suspect to not be receiving texts.
15-11-2025 09:06 PM
03-02-2026 05:42 PM
So I've worked out that if I send myself a text message then I receive texts immediately after for a period of time but half to do this every time when I know a text is coming.
It's almost like it's wakening the system. Could there be a setting that needs tweaking?
03-02-2026 06:08 PM
