Not getting incoming calls
RS118
Hi. My EE contract changed about 12 days ago. It would seem a few days after that first caller got a message that network not recognised.  Now just disconnects when someone dials.  My phone does not connect at all. When I go on EE app,  it is showing incorrect contract ie 1gb instead of 20gb pet month. Wondering if these are linked. Help please!!
7 REPLIES 7
RS118
What do you mean by your contract changing?
Does your phone show coverage indicators? Can you make outgoing calls OK?
Hi
Was with EE on a different contract which finished on 18th November so changed to another SIM only plan. Can make outgoing calls but incoming no joy...think this had happened over last few days. Yes getting signal bars.
Also, although I am on 20gb per month data and I am getting 20gb, the plan shows 1gb/month...go figure
That's just a change of priceplan, which should otherwise have no bearing on your service.
Assuming you have restarted your phone, does this affect calls from just particular numbers or all callers?
Edited to add: The discrepancy in your myEE view would have no bearing on voice call service.
Christopher_G
Hi @RS118
Welcome to the community.
I think it will be worth giving our Mobile Care team a call on 150 so that they can check everything from our side for you.
X
LinkedIn
Facebook
YouTube
