No signal
Melissaw11_
I have no signal at all since iv landed! This is a job I need my phone for work
in Spain
@Melissaw11_   Have you activated roaming on your a account?  Have you tried restarting the device?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
