on 19-02-2023 11:15 AM
Cannot make or receive calls.. says no network connection.. I've taken sim card out and cleaned and restarted phone...
I'm sim only and pay in DD so no billing issues ??
on 19-02-2023 11:24 AM
Hi @Lizzie1948
What device do you have and where did you get it?
Are you in the UK?
on 19-02-2023 11:34 AM
@Lizzie1948 Have you had a look at the network status in your area ? Have a look at THIS and click the check status tab. If there is a fault it will say you could also report an issue.
