History of phone calls
Ashmalin
Can I get access to history of the phone calls I received and I made in my number
@Ashmalin  Only if you had itemised billing at that time and this will only be outbound calls.
There is no history that EE keeps about incoming calls to your device, as that is not your personal data.   Your only option to see this sort of history is to look at your incoming call log on your device.
richarddobbs
How do I access this
@richarddobbs : It's on your phone as Call History or Recants.
Hi thanx for info . Just wondering if I received some important calls but cleared the log history by mistake. Now I need those numbers,how can I retrieve them.
@Hans4188  you can not get them if you cleared the history
