No network
Sha29
I have travelled to Portugal and I can’t access my phone keeps on saying no network I don’t have bars on the phone
@Sha29  if you’re on contract, did you enable roaming on your EE account?  If roaming is enabled on your account, have you tried restarting your device since you got there?
@Sha29 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
