on 03-10-2023 10:49 PM
Roaming all worked fine in Canada and my UK phone has USA/ Canada etc Roaming- no connection in Juneau Alaska and no networks visible in Auto or Manual search
Solved! Go to Solution.
on 03-10-2023 11:04 PM
If no networks are visible in a manual network search, that is the reason for your phone not having coverage.
EE roaming allows your phone to use foreign networks, but has no control over the coverage offered. You appear to be in an area without mobile network service - enjoy the trip!
