My phone
Nikola12
Am currently in Florida & my EE acount is not working can’t make calls or receive messages
@Nikola12 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
@Nikola12  Have you enable roaming from within your online account if you a contract customer?   Have you purchased any add on so you can use your allowances while there ?  If you have this doesn’t enable roaming as that an account setting that needs to be enabled.
