17-07-2023 01:51 PM
17-07-2023 01:57 PM - edited 17-07-2023 01:57 PM
Hi @NikkidePina,
Have you tried checking for problems in your area using the Network & Coverage Tool? Click 'Check Status'.
Does this happen if you put your sim into another phone?
Are you currently in the UK?
How many bars of reception does it show you have?
Sorry for all the questions, but this will help isolate the problem 😊
Thanks,
Alex
