Mobile signal Tenerife
Iain07
im currently in Tenerife and have no internet connection. My phone is saying it is on Moviestar network and has 4G/5G but won’t send txts or connect to internet. I have set data roaming on and have rebooted the phone I tried to manually select a network but no luck. Any help would be greatly appreciated
Christopher_G
Are you able to check your spend cap on the My EE desktop site, @Iain07?
7 REPLIES 7
Christopher_G
Hi @Iain07
Welcome to the community.
 Is it working any better today? Do you have an active spend cap?
Hi Chris,
no doesn’t seem to be working today I don’t think I have a spend cap, I tried to send the roaming txt and it came through saying ready to go but still nothing.
Christopher_G
Is your phone showing a signal on Movistar, @Iain07?
Yeah it’s showing Moviestar with 4G/5G
Christopher_G
Just checked looks like that was the problem thanks so much for all your help!
Christopher_G
Ah that's a relief, @Iain07 🙂
Glad you're sorted. Enjoy the rest of your trip.
