Mobile data not working abroad
Alir23
Have set up Roaming but my son's mobile data on his Pixel 4a isn't working in the US. Have tried restarting etc. Any further suggestions?
@Alir23 : Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Does your son have coverage displayed, of a local network in the USA? That would be a good test of whether international roaming is enabled on his phone/tablet.
Without roaming being active, a phone cannot connect to foreign networks - rendering voice calls, text messages & mobile data impossible.
Thank you for taking the time to reply - unfortunately, he couldn't get anything, including your suggestions, to work, so we are now hoping for a refund on the Roaming charge as he'll be home shortly.
