Mexico
Steve0771875676
Can someone at Ee help we are in Mexico and have no services at all so can’t contact Ee through the normal Chanel’s.
@Steve0771875676 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
