14-05-2023 06:12 PM
Hi does anybody know what this means please?
Message could not be delivered, because of error (code 064).
14-05-2023 06:34 PM
14-05-2023 10:22 PM
Hi does anybody know what error code 064 means?
15-05-2023 07:50 AM
Hi @Loupit
It is normally a code relating to the network, or credit to send the messages.
Are you in the UK?
Are you on EE PAYG or pay monthly contract?
15-05-2023 10:26 AM
Hi I’m on pay monthly and I have no problems with any other numbers. It’s the receiving number that has a problem and that is also an EE number. I’ve tried other phones to call it and and it’s a voicemail saying calls not currently being connected to this number, if you’ve dialled correctly I’m afraid it means that calls are not being accepted from the network. Then it goes to a welcome to EE voicemail to leave a message. When I tried to text the number it sent a bounce back text from the number (I thought the person had text and all was resolved) but it was a message saying not delivered due to error code 064.
Any help is much appreciated x
15-05-2023 10:30 AM
Hi @Loupit
Could you check if the person you are trying to contact has blocked your number if their phone settings?
Can they receive calls and texts from all other numbers?
15-05-2023 10:50 AM
15-05-2023 10:59 AM
Thanks @Loupit
The account holder of the number you are calling will need to contact us to get this looked into.
15-05-2023 01:57 PM
Ok. Thanks for your help.
seems like a definite issue then that needs fixed.
15-05-2023 02:18 PM
If this is affecting all calls and texts, this would need looked into @Loupit
